For those with cages.....
Discussion in 'The Garage' started by big pappa b, Jul 3, 2003.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Bolted in. I don't want the energy from a roll transered to me.
  3. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    niether, mine is using subbliminal forces "gravity" to hold it in place untill I bolt it in.......
    But I don't drive it yet so it's ok
  4. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Welded in, not to the frame.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Neither.
    Mine (in the truggy) and my son's (multi-use K5) is quite different than most. They are not "tied to the frame" in the normal sense, but rather they bolt to the body mounts on the frame. For most applications, I personally don't care for the either the normal "tie it to the frame" or the "bolt to the floor" approaches. They each have their place, but I think there are better ways for most of us...
    The truggy has a square tube subframe that the cage is attached to. The subframe sets on the factory rubber body mounts and uses factory fasteners. The cage bolts to the subframe. And the "body" (floor, cowl, windshield) bolt inside the cage/subframe. So, "body" bolts inside cage, and cage is mounted to frame; the body never touches the frame.
    My son's is not so radical, but neither is the use. We cut out the factory body braces where it sets on the body mounts and replaced it with welded in square tube (instead of the stamped sheet metal factory braces). The cage and rock sliders (raised up so they go through where the lower hinge used to be) tie into those beefier floor supports.
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    S@W roll cage welded to body. 2 bars from under floor weled to frame. Just to make sure body doesn't fall off!
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    has to sign in for the clicky
