for you 63" guys
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyguybc, Nov 9, 2006.
  1. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    hey guys, quick question, found a cheap pair locally, but they are cheap because the 3rd leaf down is broken on one.......
    i was looking them and it looks like id remove it anyways
    what do you guys runn
    this setis a 90 with 5 plus overload i belive
    im also looking at getting them rearched, i run a 77 jimmy and its gunna be smallblock 350 4 speed, loaded up with camping gear sometimes, but mostly wheeling
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    thay are 64" eye to eye length .
    #1 = broken leaf is stress passed on to others and will break sooner. = wast of money.
    #2 = rearching is big waste of money. do a search in the garage on this and find out its not worth it.
    find some others. in better shape. heck if you were closer i have a few sets and 1 set is new. i use to work springs and the guy who was my boss has been in the bissness close to 30 years. he also said and wont rearch springs.
    if you rearch to much thay wont fit in the hangers correctly as the leaf length for a given arch is now to short.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I agree partially
    Rearching to regain and inch or 2 is OK if done correctly where you shot peen the springs after you rearch them to make them memorize the arch.
    More than that and yeah the spring is too short.
    As for the broken leaf if removed you will end up with a soft spring, so if you know that and you don't intend to overload it then go for it.
    I do know that those who used the 1/2 ton springs (3 leaves) always ended up with bent springs on the fullsize trucks, 3/4 ton 5 leaves are better.
  4. cjjones
    cjjones 1/2 ton status
    Feb 20, 2006
    111
    To the north
    Factory replacement springs aren't that much money from good spring shops, I purchased all corners for under 500 bucks up here.
  5. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    try 20 bucks for this set of 63s.. even for mock up they are worth it, plus ive got spare leafs
    good info about the re arch i wont go that way.. just gotta find some used lifted ones theni guess or re arch another set
