ford 10.25 f/f
Discussion in 'The Garage' started by uberbeans, Nov 25, 2006.
  1. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    I may have an opportunity to get a ford 10.25 ff out of a F-250HD (for free). Is this worthwhile? Is the width wrong, anyone done it? Be brutally honest and try to look past the "F" word.
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    its not a Ford axle, its a Sterling. so like a HP 44 or HP 60, its technically not a Ford piece.
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    check pirate, i know those axles have a few weird quirks and year splits with their run. but they are just as strong as a d70 or 14 bolt.
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah pretty sure that is a sterling axle. good axle, just be sure you are getting the one with the right bolt pattern. in the last few years ford switched to a funky metric bolt pattern.
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    If it has discs, the bolt pattern is metric. Drum versions are 8-on-6.5".
    The pinion problem affects the earlier version. I think the split is around '90 or so. Even so, a different gearset & yoke are all it takes to fix.
  6. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    I had one, junked it, needed rebuliding, and i decided it wasn't worth the time, A little more expensive then a 14 bolt for parts, I would just wait for a 14 bolt.
  7. uberbeans
    May 14, 2004
    564
    So a problem I may have is having two different wheel bolt patterns? The only reason I am considering it is because it is cheap. But it may not turn out to be so if I have do alot to make it work. What do you guys think, is it worth it?
  8. u2slow
    May 9, 2001
    2,217
    BC Canada
    What year is this F250HD? Metric pattern (& discs) is a Superduty thing. The previous ones are drum and a normal 8x6.5" pattern.
  9. uberbeans
    May 14, 2004
    564
    I don't know what year. It is pre-superduty years, though. Probably around a '90. I was at my mother in laws for thanksgiving and saw it in her barn. It's her ex-husbands and she doesn't care about it (and obviously neither does he). It has been sitting for about 3.5 years. It has drum brakes. Worth a shot? I didn't measure the width.
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    How about driving the Ford instead? :haha:
    You'd have to move the perches to swap it into a Chevy. Make sure it has a ratio you can use - 3.55 is very common, but doesn't match anything GM. 3.73 (2wd) and 4.10 also came. The posi is decent - not a gov-bomb. The Ford hubs stick out more and are a little fatter (stock Chevy wheels won't fit).
    It is a beefy diff, 35-spline, and may have a D70 beat on tooth contact area. :eek1: Drums are 12x2.5" - not quite as big as the 14bFF ones.
    HTH
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    iirc the metric pattern only came on the 10.5" version, which is the newer one. i think you should be ok.
