Ford 10.25 full floating rear end
Discussion in 'The Garage' started by mr.smartass, Jul 2, 2006.
  1. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Well i just paid $20 bucks for one in fairly good condition, when i first saw it i thought it was a gm 14-bolt but i started counting and there were only 12... lol and the pinion gear says ford on it... i really don't know much about them i was just wondering if it's worth the time and money to rebuild, how expensive parts are (like a locker) and how hard would it be to bolt it under my '89 k5...
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    They are worth the money. They are almost as strong as a 14bff and they don't act as much like a land anchor like a 14bff. I would have no problem building one and installing it in my truck.
    Harley
  3. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    anyone else think it's worth the time? I actually thought about just taking it to the scrap yard tomorrow with my other crap... but if gears and and parts aren't to bad i might keep it... anyone else got any in put? Does anyone run one?
  4. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Keep it and use it. If you already have a 14BFF then scrap it or sell it to a friend that needs a good axle.
  5. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    nope still got my 10-bolts... what about finding a matching front end, same ratio and everything... i've got the cover off but haven't checked the ratio yet, i'm just checking to make sure i'm not getting in over my head...
  6. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Randy's ring and pinion doesn't list alot of sizes but there are some available.
  7. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    the guy that owns sport truck usa here in MICH. uses ford axles in his truck. mostly cuz they are the same width. it was featured in offroed mag. the one 4wheel parts sends out.1-734-449-9448 is the # if you want to call.i'll see if i can find the pic.
  8. boggerless
    May 26, 2003
    22,728
    96
    its the white chevy,hopefully you can see it.
  9. boggerless
    May 26, 2003
    22,728
    96
    click on it i got the pic to enlarge.
  10. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    i know i've got a bunch of dumb questions... but there's a difference between gm and ford 8 lug pattern right?
  11. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Yep, if it's from the 1999 and up trucks, which it more than likely is, it's a metric lug pattern and won't work with regular 8x6.5 wheels.
  12. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    well they used the axles since like '83 and it doesn't look like it's out of a newer truck... where can i go to match some numbers up? But if it's older it could possibly be 8x6.5?
  13. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I agree that this axle is worth using.... Most people overlook it.
    There is a "trouble" version of it though...
    Seems like 92, 93 (or somewhere around there) and older used a pinion and yoke that had short engagement.... The fix was to swap in the newer pinion (which you'd do to re-gear it anyways...) and yoke.
    I have one of the good ones.... if you need, I can take some measurements and send you the #'s....
    Marv
  14. boggerless
    May 26, 2003
    22,728
    96
    yepper,inches= GM, MM = ford.:confused: i drove from detroit mich almost to penn because i screwed up.:doah: :D to exchange rims.
  15. boggerless
    May 26, 2003
    22,728
    96
    your are right sir on the year.cuz the rims off a 96 do not fit a 2000.
  16. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    If it were newer, you'd know, wouldnt it have disc brakes? When did ford go to rear discs on the super dutys? Ehh who cares, lol.
  17. huntingaddict
    huntingaddict Registered Member
    Jun 21, 2006
    44
    Bethlehem, GA
    Yes in 99 they changed the lug pattern and went to discs at the same time. These rears are super strong. I load the heck out of my F350 and have about 800 lb/ft. from the powerstroke.....with a little work on it.
