Ford 205 32 spline front ouput info
Discussion in 'The Garage' started by FWP, Oct 15, 2005.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    For the folks that might need this info. (what I know from my conversion)
    Same front and rear bearing retainer and same bearings as 10 spline.
    A 208 front yoke fits, but a different seal is required to change from 10 spline - CR# 18872, and you need the nut that fits the Ford 32 spline shaft.
    You can't use the 208 slinger, nor the ford Spicer slinger on the 208 yoke (I went without a slinger)- it will hit the bearing retainer.
    You could use the ford yoke if you have a spicer CV, they match (I changed to the Saginaw CV).
    FWIW
    Good luck!
  2. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Thank you for the info. I will be doing this swap soon too..
