Ford 205 and GM 203. Can it be done?
Discussion in 'OffRoad Design' started by BigOrange90Jimmy, Mar 24, 2003.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I have finally lined up a 203 for my 465, but I thought about using a Ford D60 for driveshaft issues. Can the GM 203 be used in conjunction with the Ford 205? Or will I just have to go with the divorced style Doubler adapter?
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I think if you go to ORD's web page and read the write up on their Jimmy you'd find that is what they did on it.
  3. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Thanks! /forums/images/graemlins/thumb.gif Guess I didn't read it well enough.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    No problem, we have a couple different options even. Basically you can lay them both out flat like I did or use a more conventional setup with the 203 in the stock location and the 205 turned up for a bit more clearance. Either way is possible and somewhat common for us.
  5. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    which Ford 205 would you suggest using, the divorced or married style? I can get both local to me very cheap, so come with your opinion.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You should use the married ford case, the divorced is probably possible but you have to do a bunch of machine work and replace the input so it's not really worth it. The married case is a bolt up fit.
