ford 205 in a blazer for a doubler
Discussion in 'OffRoad Design' started by Seventy4Blazer, Feb 23, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    can i use a ford 205 for my doubler? i know it would have to be rotated about 180*. but will it work like that? the vents and all. i can get a ford 205 cheap. also, do i need a specific input for the ford model?
    Grant
    take me drunk, i am home
    <a target="_blank" href=http://www.geocities.com/seventy4blazer/>www.geocities.com/seventy4blazer/</a>
    <a target="_blank" href=http://www.geocities.com/seventy4blazer/parts4sale.html>www.geocities.com/seventy4blazer/parts4sale.html</a>
    <P ID="edit"><FONT class="small">Edited by Seventy4Blazer on 02/23/02 10:36 PM.</FONT></P>
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The only way we build to use a ford 205 is if you have a LH front axle, if you have a RH front axle, you should use a GM 205. It's possible to turn the ford 205 upside down but it's a really ugly way of doing it, in addition to making everything hard about it. Shifters, vents, speedo, all become problems. A GM case is much cleaner and easier overall.
    You can swap the ford input gear into the GM 205 and we can supply you a 31 spline shaft with the Doubler, so that's not a problem. That would save you a good bit of the conversion cost.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    thats just un-ethical. keep your rig all GM.
  4. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    go tto use the parts you have access to, but i wont be doing it. i dont want to run a right hand axle.
    might run the input gear though.
    dont know yet. have a few more leads on a 205 i need to check out.
    Grant
