Ford 205 tcase?
Discussion in 'The Garage' started by Jagged, May 13, 2005.
  1. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Been trying to do some searching on this; I've found a ford np205 that I can get real cheap and was wanting to know what's different from a chevy 205 (and some info about swapping the 208 for the 205)
    thanks for any links or advice you have :)
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    for starters it has the front driveline drop on the wrong side...
  3. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    duh just make me feel stupid ;)
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    That you'd need a Furd front axle to hook up to it because the drop is on the wrong side.
  5. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Buy it!..... 'specially if you can get a good deal.
    The Ford 205 IS a driver's side drop, but it has it's qualities..
    1) 32 spline outputs
    2) The 31 spline input shaft can be used to make a "low $$" doubler
    3) You may later find a driver's side drop D60 front that you wanna use in conjunction w/ a doubler.
    Marv
  6. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    the 88-up solid axle swaps with ford axles need this.
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Elaborate please (as someone sitting on a Ford 205 and a couple 203s)
