Ford 57 inch spring questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Judd, Oct 3, 2002.
  1. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    I've been reading about the Ford spring conversion and it says the spring bolt is something like 25 inches from the front of the spring eye. Stock, it's something like 26. They say to redrill the spring pack to fix. Could you just flip the spring around backwards? I would like to relocate the axle rearward a few inches to get a better departure angle and to get a better driveshaft angle anyway{gonna sawzall the rear of the fenderwells}. Anyone know the distance from the rear spring eye to the spring pack bolt? Any ideas on this, especially as far as spring wrap goes?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    57 - 25 =
  3. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    So the spring bolt is in the middle? Wait, if were in the middle and the the distance to front spring eye is 25 inches then the spring would be 50 inches over-all-25 inches to the front and 25 inches to the rear.
    Am I missing something? Were did the other 7 inches of spring go? /forums/images/graemlins/confused.gif
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    yup that 7" is on the back side
    so running the backward without drilling would move the axle 6"
    could be off but that makes sense to me
  5. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I have a set in my garage, so I went out and checked them out and sure enough, mj is right on the money. 32" from the center pin to the spring eye on the back.
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm running my 57s backwards for exactly that reason. However, you have to watch things like geometry changes as the spring flexes when you do that. Specifically pinion angle can be a problem due to the axle being mounted on the back of that arch.
  7. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    Thank for the feedback. How bout the axle wrap issues, did you experience any?
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    <font color="blue"> Ford Super duty F250 99-02 4x4 factory leaf springs, stock height only 1000 miles of use front and rear avail
    </font color> Will these work? I'mm looking for leafs and came across these, i have the info on the 86-96 leafs and still am looking for them... /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Oh yeah, I got plenty of axle wrap, working on getting a anti-wrap bar in there now. Those springs don't control the wrap at all turned backwards. The band is on the wrong side and the leafs are too staggered on the back (now the front) to provide the resistance to wrap...
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Nope, those are too heavy, they would only be good (potentially) as donors to play with swapping leafs in and out. You definitely want the 4 leaf (plus overload is 5) F150 springs.
  11. TONYP
    Aug 13, 2002
    2,116
    so cal
    Just checked on line and can get a set from JC wipeme for $87.00 each.....can you find them cheaper... /forums/images/graemlins/ears.gif
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I get mine at a local yard for $60 a pair. Some people claim to get them cheaper but that seems to be as cheap as it gets around here. Most are quoted at $100 a pair. I would be a bit suspect of the quality of J.C. springs, I would much rather get a set of Ford's. Just make sure they come from a truck that does not look totally beaten on...
  13. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    You're doing good at that price Russ /forums/images/graemlins/deal.gif.... My best has been about $90 a pair, 'cept for 1 "u-pull-it" lot that I visited once.
    Marv
  14. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    The junk (and I do mean JUNK) yard where I got mine sells em for $60 a pair, they pull em, and they have 20+ pairs there. The spring swap is still a secret in Nebraska! /forums/images/graemlins/thumb.gif Wait...maybe it's because we don't have any rocks! /forums/images/graemlins/eek.gif
  15. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i just got back from the local pull-a-part and i gotta pair and the were $19.45 each /forums/images/graemlins/shocked.gif and i picked up a spare york for $18.95. man i love going the the junk yard
  16. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    The salvage yard here is selling me some for $50 a pair. I haven't looked for them yet but theyre are so many ford there shouldn't be too hard to find a good pair. I'm gonna see if he will trade me for my chevy stockers too
  17. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Ditto. What's cooler than poking around the junk yard for cool sh!t? /forums/images/graemlins/thumb.gif
  18. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    New ? same topic:
    Aren't the ford springs wider than the Chevy? Were you able to use unmodified Chev springhangers? /forums/images/graemlins/ears.gif
  19. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    If you get the 2wd version, they are 2.5 inches wide....juuuusst riiiiight. /forums/images/graemlins/thumb.gif
