ford 57" springs question
Discussion in 'The Garage' started by 84gmcjimmy, Apr 25, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    ford 57\" springs question
    Okay first off, is it the front or rear that are the ones I use. Second, do I just need the springs, or do I need to the mounting stuff and whatnot. Thanks, getting ready to tear the springs off the custom f-150 in my backyard. Thanks
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: ford 57\" springs question
    rear, i think they are the same width as a chevy /forums/images/graemlins/dunno.gif
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I have my fingers crossed they will be the same width /forums/images/graemlins/dunno.gif Will it give the truck any lift like the chevy 52" springs in the front would or move the axle? Thanks.
  4. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    as long as there offo f a f-150 yes they are the same width, 2 1/2" wide. /forums/images/graemlins/thumb.gif
  5. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    combined with a shackle flip it'll net you about 4" of lift. You'll also need to move the shackle hanger back at least 2.5".
    You'll also need an offset zero-rate block, or re-drill the spring pack to get the diff in the correct spot. The 57's are 25"/32" where the 52's are 26"/26". I re-drilled mine at 26.5" and did the shackle flip...then moved my shackle hanger back 2.5" and used a shackle 1.5" longer than stock.
    It's not a direct bolt in, 2 hour swap...it takes some work to make it work
    Rene
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Hey Rene, what happened to the write-up you did for swapping the springs? I saw it in the advanced tech preview forum but the link doesn't work /forums/images/graemlins/dunno.gif
    With a 4" shackle flip, or a 2.5" shackle flip will get me 4"?
