Ford 60 15" wheels?
Discussion in 'The Garage' started by M-1028, Jan 1, 2006.
  1. M-1028
    M-1028 1/2 ton status
    Feb 2, 2005
    217
    Sealy Tx
    Just wondering if was possible on a high pinion king pin ford 60. Can you clearance the calipers enough like chevys or is it not going to happen.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Not really recommened. Havta run hardly any b/s, and some calipers CANNOT be ground, others can. if you want to run 15s, get the brackets, they are on Evilbay.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    to run 15s u need to get rid of the ford dual piston calipers and get brackets and 3/4 ton chevy brakes
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    78Buford has a Ford 60 and runs 15" rims with 2.75" backspacing and they required no grinding.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    who wants 2.75" of backspacing though? Thats one hell of a scrub radius.
  6. 78Buford
    78Buford 1/2 ton status
    Apr 1, 2005
    264
    Ohio
    If you stick to narrow wheels...ie: 15x8's you'll be fine. With the 42's on 15x8's, my Ford is basically identical in track width (outside of tire to outside of tire) to 6.2Blazer's K5 with 38's on 16x10 wheels. Also, with narrow wheels you are less likely to pop a bead. 6.2Blazer may want to add something to the "popping of the bead" part. :D
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    hmm wish I knew this months ago, you know BEFORE I sold my 39.5x13.50x15 IROKs haha. Oh well, have the H1 double beadlocks now.
  8. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    2.75" BS is not exactly unusual or uncommon in these applications, and have been talked about quite a bit on this board. Hell, 3.5" BS is fairly common on many "standard" wheels so that's only 3/4" difference.
