ford 60 under k5
Discussion in 'The Garage' started by muddybuddy, Oct 4, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    will the axle bolt in as is, or will the leaf and shock mounts have to be moved? if so how much?
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Should bolt right up. I know the Dodge version D60's spring pads are .5" farther apart but I believe the Chevy and Ford spacings are the same.
  3. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    all ford parts will bolt to your springs from the axle
  4. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    sorry to hijack :o . but what year/models came with a d60 that swaps under??? what about steering?? and pass. or drvr. side drop????
  5. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    I dont know what axles you guys got by my D60FF wont bolt to my truck. Gonna have to knock the mounts off and move them in. Pretty sure mine came out of a furd.
  6. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    is it drivers side diff. and high pinion? does it have kingpins and NOT balljoints?
  7. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Hate to burst everyones bubble here, but all ford D60's are NOT direct bolt in's for chevys.
    Only '78-'79 Ford D60 fronts will bolt in to our trucks. :wink1:
    Kingpin D60 Spring perch width:
    All Chevy: 32"
    All Dodge: 32.5"
    78-79 Ford: 31.5
    85-91 Ford: 36.5"
    92+ (balljoint): 36.5"
    :pimp:
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    its a 79 d60hp :D so the shocks will work also? or do i have to reweld the tabs?
  9. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I think he means the front axle.
  10. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,608
    602
    Hooper, Utah 84315
    .5 of an inch is direct bolt I if I ever saw one the shock mounts should be moved if my momory is correct.
  11. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    Where do they measure spring pad differences from? I measured my D60 from the inside edge of each pad and it seems to be 29"? My stock 10bolt seems to measure the same, so you must measure from the center of the pads huh?
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    do these run a different type of caliper than the chevy d60? will i still be able to run 15" rims with a little grinding? i thought i read somewhere that the ford calipers were different and wouldnt work or something???
  13. kgblazerfive
    Dec 2, 2004
    10,608
    602
    Hooper, Utah 84315
    My 44 from a 78 F250 bolted right in but the calipers are like twice the size of Chevies and you would have to run 16.5 or have no backspacing on your rims
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    and i jus bought 15" rims and tires.....maybe i should wait for a chevy d60. is there anyway to swap calipers to make it so 15s will fit?
  15. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    You should measure center to center, as this is where the spring connects to the pad. Otherwise if you measure from an outside edge of the pads, a difference in spring pad width would improperly skew any comparison between the two setups.
  16. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The ford calipers are different, there bigger, two piston calipers, mounting brackets are also different.
