Ford 8 bolt OEM rim fit ok on GM?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wstolar, Nov 22, 2002.
  1. wstolar
    wstolar Registered Member
    Sep 17, 2000
    46
    I found some Ford steel dish 8 bolt rims in 8.75x16.5. I've heard that the center holes aren't quite the same between Ford and GM. I can't remember if the Ford rim will fit ok on the GM axle? Anyone? I'd like to run a 39.5/15-16.5 Swamper TSL on these rims.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Ford wheels will fit GM. GM has the smallest center-holes on their 8-lug wheels.
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I believe he is correct. The bolt pattern and lug size are the same (although I think Ford used longer studs, so your lug nuts may bottom out if they are not the "open" style or "deep" enough). At the pulls, we have had trouble when trying to swap tires from Chevy to Ford (but a 4" grinder and some time cured that /forums/images/graemlins/blush.gif and NOT recommended), but no problems Ford to Chevy assuming stock rims (aftermarket wheels usually have a center hole large enough to cover Ford, Chevy, and Dodge). I'm not sure about Dodge's center hole as we have not had to swap tires onto one or from one.
  4. u2slow
    May 9, 2001
    2,217
    BC Canada
    The Dodge is at least as big - or possibly bigger - than the Ford.
  5. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Just remember that anything from a Ford installed on your Chevy could cause the overall value of your vehicle to drop dramatically. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Ford, GM or Dodge 8 lug is the same bolt pattern, except the latest superduty Fords which have a unique size, and they don't have much support in the aftermarket yet for that size.
  7. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    Ford stock 8-luggers up to the '98 Super Dutys, have the largest center hole. Some of the Dodge's are the same & most, if not all GM's are smaller. I recieved a crash course when trying to find stock 16" wheels for my '78 F-250.
    Doc
