Ford 9" Front & Rear Swap w/Crossover Steering!
Discussion in 'The Garage' started by az88k5, Nov 22, 2004.
  1. az88k5
    az88k5 1/2 ton status
    Oct 14, 2004
    258
    Prescott Valley, AZ
    Ford 9\" Front & Rear Swap w/Crossover Steering!
    Anyone done this ever on a K5? Looking for some info. Currently have 10bolts front and Rear 3.73's. /forums/images/graemlins/thinking.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Ford 9\" Front & Rear Swap W/Lockers & Crossover Steering!
    A Ford 9" is not of sufficient size to even be worth swapping into a fullsize rig in my opinion.
  3. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    You don't think a ford 9" is stronger than a GM 10Bolt or 12Bolt? /forums/images/graemlins/whistling.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It is stronger, but not sufficiently stronger that I'd unbolt a GM 10 or 12 bolt and bolt in a 9".
  5. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    What about this. Keep the 10 Bolt front, installing crossover steering. Then swapping the rear 10Bolt for a Ford 9" vs. the GM 14Bolt. /forums/images/graemlins/thinking.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Once again, a 9" is not sufficiently strong to hold up to the abuse that a fullsize rig is capable of putting to it.
    Just get a 14 bolt. They're like a 9" on steroids, MUCH stronger due to design, and they'll take 40"+ tires without a problem.
    If a Ford 9" was that great I would have had one a long time ago....but they're NOT.
  7. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    Just get a 14 bolt. They're like a 9" on steroids, MUCH stronger due to design, and they'll take without a problem.
    I don't really need 40"+ tires but that's cool. A shaved 14 Bolt would be nice. /forums/images/graemlins/woot.gif /forums/images/graemlins/thumb.gif
  8. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: Ford 9\" Front & Rear Swap w/Crossover Steering!
    I wouldn't do it for the front, that's just way too overboard in the custom bling bling factor, not to mention I think those custom fronts are big money.
    As for the rear, go for it. The 9" is a pretty nice setup and the aftermarket is solidly behind.
    As for the negative comments already made in this thread, just a bunch of clueless dumbass comments for ya. Take them for what they are worth. There's a good reason why a lot of racers (street, off-road, what have ya) have rearends based on the 9". That should tell ya something.
    By the way, have anymore questions on this, go for it. I'm swapping to a 9 in my K5.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Can't you do a cheap junkyard disc brake conversion on the 9 inch using late 70's Lincoln parts ? There is even a narrow 9 inch with discs in the Lincoln Versailles ( think Granada/fairmont chassis aka fox chassis ) for S-10 and Cherokee types . I am a Chevy guy , but came from cars where a 9 inch isn't inconceivable in sub 11 second cars , hell I remember companies selling them with a-body brackets on them .......I just thumnbed through a 2 year Hot Rod , they still do /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the lincoln granada monarch was not a Fox chassis
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah, semi floating axles sure are strong. I should figure out how to build a semi floating front axle. /forums/images/graemlins/rolleyes.gif
  12. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    there are many offroaders using ford 9s in the rear of their trucks. This is true for rocks and even prerunners. The aftermarket [i.e. Currie Enterprises] can outfit you with a rear with your spring perches already where you need them, disk brakes, full floater conversion, locker, and even chromo shafts!
    The cost?
    It would be cool to find one of those lincolns with a ford nine and disks already in it though. And it would be way cheaper, not to mention the abuse factor was probably not even bugging a car.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Does anyone know the diameter of a 31 spline Ford 9" axleshaft?
  14. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Tim not everyone wants to run 40s. If I were going to build a rig on like 35s or maybe even 37s I'd seriouslly look at if not only look at a 9". 10 bolt and 12 bolt suck.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    On what grounds? C clips?
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    c clips and 9" aftermarket is more extensive
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I can't imagine why you'd need anything aftermarket to run a set of 35-37" tires. 10 bolt/14 bolt would work just fine.
  18. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I am not really up on Furd's , but I remember the frontends of the fairmont was the same as Mustangs . Anyway here is a list from some people who know more than I http://www.coolcats.net/tech/reference/foxcars.html :
    FORD FAIRMONT 1978-83 (105.5" wheelbase; 2-door, 4-door, station wagon)
    MERCURY ZEPHYR 1978-83 (105.5" wheelbase; Z-7 coupe, Villager wagon)
    FORD FAIRMONT FUTURA 1979-82 (105.5" wheelbase; 2-door only)
    FORD MUSTANG 1979-93 (100.4" wheelbase; 3-door hatchback, 2-door coupe)
    MERCURY CAPRI 1979-86 (100.4" wheelbase; 3-door hatchback, 2-door coupe)
    FORD GRANADA 1980-82 (105.5" wheelbase; 2-door, 4-door, station wagon)
    MERCURY COUGAR 1980-82 (108.2" wheelbase; 2-door, 4-door, station wagon)
    FORD THUNDERBIRD 1980-82 (108.2" wheelbase; 2-door only)
    FORD LTD 1982-85 (105.6" wheelbase; 4-door, station wagon)
    MERCURY MARQUIS 1982-85 (105.6" wheelbase; 4-door, station wagon)
    LINCOLN CONTINENTAL 1982-87 (112.0" wheelbase; 2-door only)
    MERCURY COUGAR 1983-86 (103.8" wheelbase; 2-door only)
    FORD THUNDERBIRD 1983-86 (103.8" wheelbase; 2-door only)
    LINCOLN MARK VII 1984-92 (112.0" wheelbase; 2-door only)
    MERCURY COUGAR 1987-88 (104.2" wheelbase; 2-door only)
    FORD THUNDERBIRD 1987-88 (104.2" wheelbase; 2-door only)
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    unless you didn't want the weight and low ground clearance of a 14 bolt. A Shaved 9" is a few more inches ground clearance even compared to a shaved 14 bolt.
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    When I ran 35s I ran a 14 SF. Stronger than all but the most pimped out 9" axles and cost me exactly nothing. /forums/images/graemlins/rotfl.gif
