ford 9" in a k5?
Discussion in 'The Garage' started by beastofablaze, Jul 5, 2006.
  1. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    Is it feasable? I want more strength and don't want to give too much clearence. I know you can trim a 14b but how much do ford 9" go for and would I need to shorten it? What rigs have good or bad 9" rear ends?
    I had a conversation with a ford guy and he had a good point... chevy makes good engines but the axles are turds. I have access to EVERYTHING I could need to fab a setup at work just need some info.
    Anybody done it?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    I'd look for an 80-86 9 inch, with 70-79's being second. You could also convert your d44/10b using ford five lug hubs, or convert the rear to 6 lug (custom axles). Or run 6 lugs up front and 5's out back. Other than the wheel hub patterns, thats the only drawback I see. Good luck on the swap.
    I see 9" in the paper drum to drum anywhere from $125 to $400.
  3. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    here is how I see this thing, lotsa old school guys use the 9 incher for race applications, the things work great and will take a lot of punishment, as far as the actual gearset is concerned, tbe shafts are the only thing I can see as the problem, as with racing the shafts twist in half. if someone could design a spool that fits a furd 9 inch AND have it accept atleast 1.75 inch shafts, the thing would rule the world as we now know it, it would have to have larger tubes and a indestructable steering knuckle for the front end. I keep thinking about this combo, maybe I'll just give the boys down at Modine MFG a call and see if their intrested???
  4. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    9" spools are available for 40 splines that use 2 inch diameter axle shafts. Most in that range are gun drilled (rear axles). My buddy runs a Strange 9 inch in his drag car with said axles/spool.
    All of the rock crawling competition 9's from currie and the like use 40 spline shafts and modified ARB's. The stuff is already out there, no need to find a custom axle builder.
  6. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Ive heard of people using them in front applications too. Is this right?
  7. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    yes, 9" center section and D60 outers
  8. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I believe Bubba Ray Boudreaux here on CK5 has a 9" in his K5. Maybe he will chime in.:D
  9. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
  10. PeteH
    Mar 26, 2003
    498
    San Jose
    needs some trussing though
  11. beastofablaze
    Apr 4, 2005
    441
    CA
  12. PeteH
    Mar 26, 2003
    498
    San Jose
    originally posted by peteh? waaaa?
  13. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
