Ford 9 inch or 9.5 SF???
Discussion in 'The Garage' started by ryan22re, Oct 31, 2006.
9 inch or 9.5 SF ???
  1. 9 inch
    10 vote(s)
    31.3%
  2. 9.5 SF
    10 vote(s)
    31.3%
  3. Nekkid with my 14 bolt.
    12 vote(s)
    37.5%
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    9 inch
    Pros: Huge aftermarket support, non c clip axles, maybe find one with a limited slip. Availability, low cost
    Cons: 5 lug, stock axles are usually 28 spline, and it's a Ford. No idea what kinds of gears would come stock for most fords. My guess would be a 3.50.
    No idea on the WMS to WMS on fullsize fords, but I'd guess it's close enough.
    9.5 SF
    Pros: GM made, six lug possible with stock parts, 33 spline probably easy to find with 3.73's or 4.10's
    Cons: c-clip axle, aftermarket support, expensive lockers??? could find one with a gov-lock. Availability?? Cost???
    What would you run?
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    To do what with, and in what?
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    Overall, if you get the "good" 9" housing it is the better choice. Removeable third member, third pinion bearing (in addition to awesome gear contact and size), no need for an aftermarket cover, the list goes on. If you go the 9" route you will be in for aftermarket shafts (easy to order with the 6 or 8 lug pattern). The SF 14 bolt will be cheaper and easier but is not as good in a bunch of ways. Pretty much the only thing the SF 14 bolt has that is better is cost and it is an easier swap.
    My vote goes to FF 14 bolt regardless.
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Replace the 10 bolt rearend in my blazer. Probably with 33's or 35's. Have to downsize and build as cheap as possible.
  5. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    well put! lol, this gets my vote as well.
  6. 1977k5
    May 26, 2003
    9,995
    133
    If you are sticking with 33's or 35's why worry about changing at all? If you are easy on it you can make 35's survive on 1/2 tons. If you have toasted your stock axle, replace it or accept that you are abusing it worse than it can take.
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Well, I'm dreaming right now, I have to sell my 60/14ff to pay some bills before the baby comes. The 10 bolt currenly in it has seen better days. It has 2.73's and needs pinion/carrier bearings and a yoke/u joint and probably more.
    I just can't seeing spending too much money on it (the 10 bolt). Plus I'd like to add a traction device, deeper gears and have some reliability (more than what a 10 bolt can offer).
    Maybe the one tons won't sell. Then there won't be a question.
  8. 1977k5
    May 26, 2003
    9,995
    133
    Man, with 2.73's and in need of diff. bearings I would chuck that thing in the dumpster. I would look for pretty much any diff. I could find with the gears I wanted at the junkyard. Its up to you if the 8 lug business is worth it. The traction device thing is also up to you, practically everything you will find in a Chevy is either a gov-lok or open.
    If money is the concern the 9" is probably way out of the picture IMO.
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    That's why I threw in the 9.5 SF. Probably could pick one up with the gears I want, gov-lock or open.
    But then again, for the same money, I could probably buy two decent ten bolts with 3.42's or 3.73's.
    Decisions, decisions.
  10. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    BTW. from what I've seen (take it with a grain of salt) on the internet, the 9 inch rearends from f100/f150's (late 70's/early 80's) are ~60-61 inches WMS to WMS. Ford vans are around 65 which would make them just right. But they may have an uncentered pinion, which would suck.
    The 10 bolt or 9.5 SF is looking better and better.
  11. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'd go 9.5" semi floater, if it's not a trail only rig and you don't drive like me and it's on 35's or less, you can find light duty 3/4 tons with 3.73's and gov locks for pretty cheap.
    I swapped one into my '93 about 6 months before I sold it. Everything on the truck was going south so I rodded it about as hard as I could (33's, 3.73's, all pavement) for those last months and it survived. Obviously it's not off-road shock loads but I'm not easy on things no matter where they're driven.
  12. SUPERSUB87
    SUPERSUB87 1/2 ton status
    Oct 16, 2006
    463
    TEXAS
    ok... so you are selling your d60... which is probably an 8-lug correct??? if it is... and you want to save money go with a 14ff or even a 14sf should be fine with 35's they are pretty tough. and come in 6 or 8-lug. if your looking for a front then i would say find a 3/4 ton sub with a d44 front... they are a steal at various junkyards. and can hold up 35's... after all a lot of ppl run anywhere form 37'sx13.50 (me), 38x11, and even some 39's and basing101 runs 44's<----crazy. but they are pretty dependable. unless you dont care about your wheels. then screw what i just said. just thinkin since you probably had 8 lugs that it would be a good thing
  13. ntsqd
    Nov 28, 2002
    3,381
    So. CA
  14. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
  15. goldwing2000
    goldwing2000 Guest
    Too bad you're not closer... I have a matched set of 1/2-ton gear with 3.42 ratio that's collecting dust in my back yard.
    Why don't you sell the D60, keep the 14bff and just re-gear your front 10-bolt to match?
  16. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    do the 9" if you can
  17. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Looks like I may have the 60/14ff sold and a set of 3.42 10 bolts as part of the deal.
  18. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    :thinking: :thinking: :xmas: <--Santa's back!
  19. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Who do you mean by Santa....?
    Perhaps our little buddy from Spartanburg :D ?
  20. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    If you look around, you can find 31 spline models. I picked mine up for $125 from a guy on PBB.....................................:D
    WMS is pretty close, but the spring perches have to be cut and replaced.
