Ford 9 inch??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big76, Sep 25, 2000.
  1. big76
    big76 Registered Member
    Sep 25, 2000
    10
    Arkansas
    Iv'e heard that one of the best rearends you can put under an off road vehicle is a ford 9 inch. I have one with factory disc brakes but I was wondering how much work it will be and if i'll be able to do it myself. I can do it all except for cutting and welding. I want to put it under a '76 blazer with a 6inch lift and 35 inch tires. I also am wondering what gears to run. I mainly use it for fun and I have a th350 trans hooked to a 350 motor
  2. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    Those are fine, fine rear ends. I'm not quite sure what had factory disc brakes (old lincoln?), but if you make sure the width is at least the same as your original rear axle (or up to 4" wider i'd say), you shouldn't have any problem except the wheel bolt-pattern.
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  3. big76
    Sep 25, 2000
    10
    Arkansas
    The 9inch was from an old '78(?) Ford LTD Landau. ex-demolition derby car.
  4. Woodman89
    Woodman89 Registered Member
    Jul 27, 2000
    60
    New Hampshire
    The ford 9" is a great rearend, but if you have a lincoln rear it may not be a good choice for a truck because they have fixed calipers. Fixed calipers produce a lot of stress on the rotors, and when you factor in the amount of force it takes to stop a truck (opposed to a lincoln) it may be a problem. Im sure it can be done, but it might work better in the long run to just get a disk conversion kit that has floating calipers. Not to mention some of the parts for a linclon rear are hard to come by if the one you have is not complete (dust shields, ebrake brackets, seals). Ive done this conversion before on a mustang (sorry guys).
  5. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Also, beware of the extrememly low pinion on the 9", further aggravating driveshaft angle when you're already 6" lifted. Also, ever seen the thickness of a 9" housing? Pretty darn thin! I say if you want beef, put a 60 under there, or a 14 bolt FF.
    ken
  6. tRustyK5
    Jul 23, 2000
    36,169
    1,370
    E-town baby!
    Yeah I'd say leave the car stuff (especially Ford car stuff) to the car guys and get some real beef. I've seen a number of busted up 9" Fords under pretty tame trucks, but it is a pretty rare day to see a blown 14 bolt FF.[​IMG]
    Not only that but the 14 bolt will swap right in without cutting or welding, and it has nice big brakes. I've seen 14 bolts sold for as little as $100, they are pretty common.
    Just my humble biased opinion [​IMG]
    Rene
  7. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    A 9" rear is a very good rear for just about any vehicle. One thing to consider though is the low pinion height. the yoke comes out really low on a 9" and you need to be sure that you won't have any driveshaft binding problems. The best way to do that is to point the yoke of the axle almost directly, (about 1-2 degrees below) at the t-case yoke and then use a c-v joint driveshaft. It shouldn't be a problem to adapt it to your blazer, but with a 6" lift and the low pinion location, it's something you have to consider.
    HTH
    Buddy
    I've got my dream truck and it's a 72 K-5 that is getting there!!
  8. Grim-Reaper
    7,385
    Atlanta
    Well a Nine is one of the better things to come out of Ford that I will admit. But I will also add what I have seen on two nines that gives me concern as a off road axle. The first is they have this nasty habbit of breaking the third member on one of the internal pinion supports. I have seen 3 of these broken with trucks own by two of my buds. The second is they don't like taking pops from the side. Both my buds truck have busted the races (one has busted 2 sets) on the wheel bearings from side impacts. They do not run a open ended bearing where it wont hurt it to slide in or out some. The bearing retains the wheel and heavy shock side loading like slipping into at rock will break them. Get a 14...you can't hurt them without really trying.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  9. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    A 9 inch is lower than a Dana 60 but the pinion is also 2" shorter than a dana 60. So you can make the driveline longer and you will be in about the same boat as a Dana 60. I think that you add a back brace and you will never have a problem with it.
    Donovan
  10. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    One thing thats nice about the 9 inch is the fact that there are some really beefy replacement parts for it. Not only can you get 35 spline axle shafts for it, but I believe I read somewhere you can also get a Detroit Locker that will work with those axles. You can also get the housings directly from Currie that are way better than stock.
    As for using that stock axle out of a car...I don't know. 35's might be pushing it.
    Remember the TTC guys from a couple years ago with the old Bronco and the newer one. They both had 44 inch tires and 9 inch rearends...but the axles also had 40 spline axle shafts, etc.
    '73 K5
    Chevy good...Ford bad
  11. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    in my opinion look for a 14 FF. in my opinion, humble opinion, personal opinion, NOT A FACT opinion, just an opinion, the 14 is stronger......the end of my opinion.
    Knife.
    knife.coloradok5.com
