Ford Brake Problem
Discussion in 'The Garage' started by nkldrgr, Aug 3, 2004.
  1. nkldrgr
    nkldrgr Registered Member
    Apr 20, 2004
    54
    Seattle, WA
    Help, please! I have a `94 F350 4x4 with a 7.3. I just replaced the master cylinder, rear shoes and drums, front calipers and pads, and the proportioning valve. I did this because the pedal was soft and would slowly go all the way to the floor. The problem is that it STILL does it. There is no fluid anywhere leaking. I have bled the entire system many times using different techniques. Can anyone help???
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Leaky lines somewhere? /forums/images/graemlins/dunno.gif
  3. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    1. Replaced blue oval with bowtie.
    2. Look at hoses -- not likely, but soft hoses can bulge out.
    3. Vacuum booster shot?
    -- A
  4. 85_k5
    85_k5 Registered Member
    Oct 9, 2003
    14
    Mission B.C.
    I used to have a 90 f250 with the 7.3 and had the exact same problem. I repaced everything to do with the brake system. Had it into the dealer and they couldnt find anything wrong. I talked to numerous people who had the same problem and no one could figure it out. Its just one of those quirks ford trucks have. The only suggestion ford had was to put an exhaust brake on for easier braking. I drove the truck for 6 years with the soft pedal and brake fade, with 38" tires and a camper and never had any problems stopping. Brakes would work great if you hammered on them, just when you were stopped they would get that soft feeling and slowly fade. Now the pedal never went to the floor but it always drove me nuts. After a while I just learned to live with it. If you find the problem let us know.
  5. nkldrgr
    Apr 20, 2004
    54
    Seattle, WA
    I may just have to live with it. Thanks for your input.
