ford bronco question
Discussion in 'The Garage' started by chevyk5blazer666, Sep 6, 2005.
  1. chevyk5blazer666
    chevyk5blazer666 Registered Member
    Jul 6, 2005
    44
    N.J.
    i have a ford bronco with a 6'in lift, and i want to know if the sway bar is needed. b/c the problem im having ,is with the tbs',(twin traction beams)when i go in reverse the hole front of the truck go's up, and it is really hard to steer , i think it is b/c of the sway bar. i don't have a sway bar on my k-5 and that thing is fine that also has a 6"in lift.
    and the bronco spends half the time on the highways and half off road,
    pls help lol,,,,,,,thanx
  2. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    Sell the Broncho and get a Chevy :doah: :D
  3. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    i have a k-5 blazer an s-10 blazer ,and an 85 trans am with a 383 .lol dont tel me to go buy a chevy , im dieing on gas as it is.
  4. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    So when you put the bronco in reverse to back out of a parking spot the front end lifts up? Like an inch or so? or is the rear just squatting? Or...... maybe I am just not getting what you mean.
    You can't really compare the chevy to the ford. Every suspension component is different. Swaybars dont provide lift or support in a suspension. All they do is limit the amount of travel from side to side. That is why vehicles articulate more when they are disconnected. A benefit off-road, a hinderance on-road.
  5. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    Uh..........when you go into reverse the front end should go down, not up.
  6. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    well it go's up ,and the two front tires bow in wards ,and the camber is all kinds of fuc*ed up
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    Well, you have to expect bad and/or random camber on a TTB system. (coil springs = good, TTB = bad)
    Does it only do this in 4WD, or in 2WD as well? Are your hubs locked?
  9. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    it dose it in 4wd and in 2wd ,it is a pice of sh!t , im gonna run it over with my k-5
  10. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    I wouldn't do that. There is someone out there dumb enough to give you more than it is worth.
  11. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    the only thing i want off the whole truck is the tires,
  12. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Have you tried to remove the swaybar?Does the front normally sit higher than the rear?Maybe the rear is squatting and unloading the front to make the steering light.
  13. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    Is your track bar the right length to go with the lift. When you hit a bump or go over a hump in the road does it try a go anther direction (steering whel jerk)? Go back and look at all the brackets that would have to do with the lift and you will find one has loosened just a little i believe. Did you just put the lift on? or has the lift been on awhile and this just start? I think my friends son had to replace the track bar and do some steering correction to get his to steer right.
