ford coil sprung axle coil spacing?
Discussion in 'The Garage' started by sled_dog, Feb 28, 2006.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Can anyone measure center to center on a ford F150 coil sprung solid axle rig? Just wondering if it happens to be the same spacing as say a 1997 C2500 chevy....
  2. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    and again I'm asking....
  3. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I can check for you however my ford has ttb up front, its a 95. I dont know if that will help.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    spring spacing should be the same, plenty of folks replace ttb with solid axles out of the older rigs.
    I'd really like to use coil springs and a radius arm system(even with the bind factor) but I doubt I will since I would have to leave the axle centerline in the stock location. big tires and stock axle centerline on a SAS 89+ Chevy = firewall contact.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    why do you have to leave the axle in the stock location?
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    if I used the stock spring buckets? cause the stock spring buckets are where they are and thats that.... this is a 2wd I'm talking about SAS and 4x4 conversion at the same time.
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    i wasnt thinking about you using the stock spring buckets...:doah:i knew you were doing sas and solid axle. why not take the time to move the buckets? with all the rok it would take already, why not go that one step further so you dont have a comprimise?
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    cause it would be extremely easy to put in a radius arm setup if the spring bucket distance on an F150 is the same as the Chevy. Moving the spring buckets would require completely changing hte frame(since the chevy buckets are actually part of the factory boxed in frame).
  9. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I will gladly check, however its dark and rainging and I cant see... I will do it tommorrow after work.
