ford computer, chevy short block, ford 4r70W, and ford transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 75K5, Sep 24, 2002.
  1. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    Boy is this going to upset the gods /forums/images/icons/smile.gif
    After a long discussion with a friend in detroit, I was convinced to do bad things to my chevy. I just bought the computer, harness, MAF, and sensors from a 2000 Ford explorer. It is my intention to wire that computer into a chevy 383 small block with the holley stealth-ram intake. It will be true MAF based multi-port sequential fuel injection. I have everything I need to burn chips for the ford computer, so I am not worried about the tuning. That project will start when it gets a little colder out.
    Now for the hard part. I have been looking at the GM 4L80-E transmission, but I believe the ford 4R70W is a cheaper alternative. They make a version that bolts up to the ford 302, so the bolt pattern should be the same. I can rebuilt it stronger, so it should have no problem handling 600rwhp/600rwtq. I will be able to adjust my 2000 ford explorer computer to correctly run the 4R70W transmission. I can even get in and adjust all of the controls.
    I am doing research now on ford transfer cases. It looks like they have some electronic-shift transfer cases that will bolt up to the 4R70W and have the front driveshaft drop on the passenger side. I know I will have to have custom length driveshafts made, but that is one of the smaller road blocks.
    I wanted to drop those ideas on the group and see if there were any ideas/suggestion to add.
    Brian
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    [/ QUOTE ] Ya lost me there. What does a 302 have to do with all of this? The Ford tranny still won't bolt to your 383 without some kind of adapter.
  3. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    sorry, I typed that wrong. I meant that there's already a bunch of easy ways to mate those up without fabricating parts. This place makes an adaptor to put the ford transmission on the chevy engine. http://www.advanceadapters.com
  4. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    Ive put a chevy big block in a 71 ford and it wasnt too hard just alot of welding and fabricating but as far as hooking computerized stuff up i would think that if you went all ford period then it would be alot easier to tune and fabricate stuff. My project for this winter is to put a 2000 chevy 5.3 in my blazer fuel injection and all includin the new a/c. Something else that might help as far as wiring harness are concered look at http://www.painlessperformance.com/ they probably can make ot have a wiring harness specially for your needs. Just an idea. And i hope you have a welder!!!
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    Wow. Brave man. I would be worried about the strength and reliability of Ford electronic shift T-cases. How about Using a NP241 or something like that that came in both Fords and Chevy's? You could get one of each version and make a hybrid case that bolts to the Ford tranny but has the front output on the passenger side. Could be possible.
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what did they come in?
    I havent seen any newer ford swap info around, but havent looked.
