Ford D44 Hubs Swap for GM?
Discussion in '1992-Present Chevy & GMC models' started by Highjaxx, Dec 28, 2004.
  1. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    If my buddy put in a Ford D44 could he swap his hubs to get it back to 6-lug?
    Thanks for your help
  2. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    hub info
    i think its a easy swap just check the spindel and see if its the same as the cheve if not then swap all chevy outers . possible stub shaft also. i know dana 60 is gm/dodge and ford different but dont know if same with 44.
  3. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    Supposedly only 78/79 ford hubs would swap onto the later GM spindles (77-up). I am going to try this swap with my brother's heep.
    (Edit) Opps, you're going the opposite direction. You may have to swap everything from the knuckle out.
  4. dantheman
    dantheman Registered Member
    Nov 8, 2004
    12
    Fresno, CA
    For my bro's straight axle ('95 SAS) we swapped in a HP 44 (Ford Axle) and used everything from the knuckle out, including the outer shaft, from a chevy 44, it bolted right up.
