Ford D60 DRW Rear End?
Discussion in 'The Garage' started by PhoenixZorn, Apr 6, 2006.
  1. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    I have one of these in the yard at my shop and was wondering (other than the lug pattern) if this axle would bolt in to my 86 Blazer chassis. The axle has 4.11 gears and it's a bit rusted, but otherwise, it's 100% D60.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I'm quite sure Ford spring spacing is wider than the K5.
    Now, a DRW D60 rear.... hmmmm....
    Do you know if its a factory dually axle or a SRW axle with dually wheels slapped on it?
    If it is a dually D60, I'd guess its from a cut-away van (cubevan) and may be really wide - similar to a DRW pickup width.
  3. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    It's an original Dually rear end from like a 78 Ford pick'em up truck.
    By the way... i decided to do this swap on a Burb instead... already have one in the lineup... 1982 with no motor, likely no tranny, and if it's still there, a broken t-case. In my garage I have a 355, a SM465, and a NP208... though I wouldn't mind finding a 205 somewhere. =)
  4. u2slow
    May 9, 2001
    2,217
    BC Canada
    Ford didn't make a dually pickup in '78. :confused:
    The cab & chassis used a Dana 70. Should have 40.5" spring spacing.
    As I said before, maybe sombody slapped some DRW wheels on the more common SRW D60. :thinking:
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    the few late 70's Ford F350 drw trucks I have seen have D70 rears. SRW is the same. However, the 4x4's got the D60 for some weird reason.
  6. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    Then perhaps it's a 70... I know it's a Dana 1-ton axle out of a Ford, and I know it was a dually its whole life...
