ford d60 front diff
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sledheadak, Jul 7, 2005.
  1. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    i have a ford d60 front diff.what mods have to be done to install it in my jimmy?i have a chevy 203 and a ford 205 tcase to do a doubler with.was wondering of any problems i might run into doing this swap.thanks mike.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Easiest thing to do would be to sell you chevy 203 and get a ford 203 (do they exist?) that has the drivers side front output shaft and you'd be set.
  3. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    While Ford NP203s do exist that is NOT what you want if you are planning a doubler. Like you said you have what you need. If your Ford D60 is from a '78 or '79 the spring pads are in the right place, so you just need to worry about driveshafts & shocks. If its not you need to start measuring.
  4. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I talked to kyle.......I think at northwestfab about the same setup for my 72. He said it was best to use the chevy 203 box b/c you can clock the box and wont have the linkage issues. It will put the linkages on top. He also told me that I can choose what ever coupler I want. Fords have a 31 spline input, while most "doubler" cases use the 32 spline. I like his plates also b/c if you want to clock the 205 up or flat, you have the choice to do either. If you are in the market for the plates, I would give him a call. Very competitive price and very versitile.
    Steve
