Ford Dana 44 crossover????????
Discussion in 'The Garage' started by Corey 78K5, Apr 21, 2007.
  1. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    OK My boss's son has a 92 Chevy 1/2 ton and wants to do the SAS. He has a D44 out of a late 70's Ford 3/4 ton. It has 8 lugs ball joints discos along with the high pinion just like he wants. So he asked me if he could use it and do a cross over on it. So I went and looked at it and its steering is all on the drivers side knuckle pretty much like a Chevy. One thing I did notice though was that the passenger knuckle was flat like a 75 and older Chevy D44. So does anyone know if there is cross over kits for these axles?????
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Should be the same thing to use on any GM, Ford or Dodge.
  3. Corey 78K5
    13,055
    Humboldt County, CA
    Umm ok. Maybe I should just check with Stephen...
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    They are the same as far as the steering arm goes. The pitman arm youd have to look into. Draglink should be easy enough...
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Everything will be exactly the same as the GM 44s.
    Now get back to the LOUNGE!!!! :mad:
