ford dana 44 in a GM
Discussion in 'The Garage' started by jasonkh2tg, Apr 4, 2007.
  1. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    Ive heard that 78 and 79 leaf spring dana 44 and dana 60 have the same spring pearch spacing as solid axle gm...Just wondering if any one can confrirm or deny this...Just want to get some questions I have out of the way before I begin a SAS...thanks...
  2. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    other that the differentail being on the wrong side I'm sure you can move the perches to fit. with a grinder and welding machine/
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    he is building a ifs to solid axle.
    i have heard that the 44 ford you need is a ext cab only in a 1/2 ton as std cab was coil spring. but ext cab was leaf spring. and if 3/4 ton thay are what you need. but in a 60 front good luck finding a cheep one. thay go quick.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    some early F150s came with leaf springs no matter what they are.
    If it is a leaf sprung dana 44, it will work for you. The spacing is about .5" different than a GM front axle, but thats so little, you will barely notice.
    Go for it.
  5. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Geeze sorry I didn't read the last line obviously. My friend did exactly that when he SASd his 3/4ton. he used coils and radius arm links. . with an 8lug ford D44. worked really good.
