Ford Dana 44 outers?
Discussion in 'The Garage' started by Mudbug1979, Aug 20, 2003.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    Will a mid 80's something ford 8 lug dana 44 front end outers work on my 6lug 10bolt if I use all of the parts, calipers,backing plates,hubs, ect. Just another Idea to persue. /forums/images/graemlins/thumb.gif
  2. gmule
    gmule 1/2 ton status
    Apr 2, 2002
    196
    Conifer Colorado
    I have chevy knuckles out on my dodge. Check ball joint part numbers if they match I would think it would work
  3. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    If you do it you will need to use EVERYTHING from the knuckle itself out. The Ford spindle has 5 mounting studs where Chevy & Dodge have 6 studs. Also, I believe the stub axles and bearing hubs are shorter than Chevy & Dodge.
