Ford Dana 60 Front
Discussion in 'The Garage' started by SmokinLB7, Apr 20, 2007.
  1. SmokinLB7
    SmokinLB7 1/2 ton status
    Mar 21, 2007
    118
    Greeley, CO
    I have found a 1978 Ford D60 front. What all will take to get this bad boy under my K5. I know spring perches and shock mounts. But what about the pinion and all that, and steering. Is anything going to be much differant?
    Zach
  2. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,609
    602
    Hooper, Utah 84315
    Spring perches are the same, pumpkin is on the wrong side though if you have a chevy.
  3. SmokinLB7
    Mar 21, 2007
    118
    Greeley, CO
    Are you sure, because there is a guy selling a D60 out of a 78 F350 in the for sale section, and his pictures show it as a passanger side drop
  4. jtrux
    jtrux 1/2 ton status
    Jan 14, 2007
    185
    San Antonio, TX
    I could almost swear that I read somewhere that ford didn't make the f350 4x4 until 1979. If that's the case then it was a f250 that your d60 came out of.
  5. kgblazerfive
    Dec 2, 2004
    10,609
    602
    Hooper, Utah 84315
    Yup I'm sure the two that I own are Drivers side drop and the 44 that I owned was drivers side drop and ever Ford that I have ever seen is drivers side drop.
  6. kgblazerfive
    Dec 2, 2004
    10,609
    602
    Hooper, Utah 84315
    Look at the pics again its upside down the perches are on the bottom and the steering arm is on the bottom, and that is the front end that I have.
  7. kgblazerfive
    Dec 2, 2004
    10,609
    602
    Hooper, Utah 84315
  8. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    It will bolt in, the perches are the same width. U-joint might be the same, either a 1310 or 1330. Shock mounts are different, steering might work, brakelines maybe. The big concern is driver drop. You could swap t-cases, or sell that one, buy a GM 60. Can get more for the HP60.
  9. SmokinLB7
    Mar 21, 2007
    118
    Greeley, CO
    I knew I missed something there. I thought ford was driver drop too, but I guess I didnt really check the picture that hard...I just wanted it to be true:D
  10. SmokinLB7
    Mar 21, 2007
    118
    Greeley, CO
    The ford high pinion D60's go for more than the GM's? Really? Cuz if that is the case, i can definatly sell this one...I can get a rediculously good deal on it.
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    whats a ridiculouslly good deal?
    More? eh not so sure. About the same in the scheme of things I think. Yes the high pinion setup is more desirable, but the bigger dual piston calipers are a stumbling block for a lot of people. To run 15" rims you have to convert to 3/4 ton brakes(step down in braking power) or convert to Chevy knuckles and brakes. The Ford knuckles are weaker than the Chevy units. And the wheel studs are 1/2" instead of 9/16". So in the end I think the value sits about the same between the 2. Just depends what you want.
    I sold a GM D60 to put a High Pinion Ford 60 under my S10. Glad I did, and would do it again.
  12. SmokinLB7
    Mar 21, 2007
    118
    Greeley, CO
    $350-$400.
    Did you convert your T-Case?
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    wouldn't have needed to, an S10 has driver's drop. However could always use a NP-241 out of an IFS truck. But my S10 has a 203/205 doubler using a Ford 205, so its setup for the D60.
  14. kgblazerfive
    Dec 2, 2004
    10,609
    602
    Hooper, Utah 84315
    I sold a whole truck for $1400 and the guy wanted the front end only;) so $300-$400 is a screaming deal
