ford Dana 60
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, May 10, 2001.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    is there any way to use a ford dana60 in my blazer that would not cost me out my ass
    I found a set frount and rear for 500.00
    [​IMG]If you want to run cool
    you got to run on Heavy Heavy Fuel (106.1 RDU)
    <A target="_blank" HREF=http://www.trailblazer90.coloradok5.com>http://www.trailblazer90.coloradok5.com</A>
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Rear change spring pads and shock mount locations on the axle. Front it's gonna cost you if it can be done at all. Talking left drop versus right drop and location of the pumpkin. Ph**ds have the pumpkin located on the drivers side. Chevy's put them on the right side.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Could you get a NP231/241 from an 88-up and use it? Output is on R side I believe.
    -- Mike
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The front will require MAJOR work to be put in a K5 (tubes removed from housing and switched, spring pads, shock mounts, ect) so your better off saving for a chevy 60 if you think you need one. What year are these axles from? Pre-75 (I think) dana 60 rears had 16 splines (weak) and the ford rears were way to narrow for a K5. Ask me how I know [​IMG] [​IMG]</font color=blue>
