Ford dana 60
Discussion in 'The Garage' started by ssped, May 29, 2006.
  1. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    Will a front D60 out of a ford work in our trucks? the pinion is on the wrong side. what happens to drive line angles?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    It will work yes with a little work, you'll need a Ford Tcase too.
  3. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    IF you have a 78-79 Ford 60, it will bolt in for the most part. Sometimes Ford used 1310-1350s on the front. Shocks, steering, etc will need to be checked. And of course the t-case. Angles will be better do to the high pinion.
  4. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    imo you should go with a 241 out of a 88-98 chevy if you get that axle
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Another t-case option is to use a doubler and clock it to the drivers side.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    or a case from an 88+ IFS truck. could make things VERY easy if you already have a 208 or a 241 in your truck.
