Ford Daqna 60
Discussion in 'The Garage' started by slimlynn1, Apr 4, 2005.
  1. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Ford Dana 60
    I'm looking at a 1979 Ford F-250 Dana 60 front. Is that going to be a driver side diff or passenger side. The guy says it is pass side. I havn't seen it yet. He wants $500 for the front and rear 60s. Is this a good price? Thanks.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If it has a front D60 (only some F250's then did) it is WELL worth $500. In 78-79 the Ford D60 would have been the high pinion version which is rare and coveted by many. It should be a drivers side pumpkin.
    Most F250's (except high GVW's and SnowFighters) were high pinion D44's. So check that out before you buy it.
    $500 is an ok deal for a D60 rear with a HP D44 front. $500 is a SMOKIN deal for Dual D60's especially if they are in good shape.
    Harley
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'm 99.9% sure it'll be driver's side and high pinion. Even if you have no use for the set, buy them for $500, turn around and sell them for a boatload.
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yep, what he said. Even if you don't use the front D60 buy it for $500 and turn aronud and sell it for $800+ depending on the shape. A HP D60 often go for well over $1000 by themselves.
    Harley
  5. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    He said it is a king pin 60 front and a 60 rear. I would have to get a new transfer case then wouldn't I.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Most likely. Unless you could find someone to swap you a Chevy or Dodge D60 for the Ford D60. The Ford axle does have the advantage of the high pinion though which is a really nice thing to have. It keeps the driveshaft angles down and it keeps the driveshaft higher up away from rocks and other trail obsticals.
    Harley
  7. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I honestly wouldn't try to go to a driver's side setup, would probably be more hassle than it's worth unless you're really into it. If you are, then yeah, go for it. But honestly I'd make sure the axles were in good shape, buy them, turn around and sell them on e-bay or something and make a pretty penny. Then buy the axles you actually need.
  8. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    Thanks all for the quick replys.
  9. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    a NP241 from an IFS rig should bolt right up to your TH400, and it would give you driver's side drop. but then you'd probably have to deal with the speedo.
  10. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I have a 79 F350 Dana 60 HP in my toy. The most expensive part of converting to drivers side drop is matching up a drivers drop tcase with the rest of your drivetrain. Like was said above if you don't want to go to the hassle it is still worth it. I paid 800 for mine and believe I got a good deal. Everything else to converting to drivers drop is much less expensive but a good deal of hassle. Exhaust can be problematic, crossmembers, shifters and linkages are just some of the things that come to mind.
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I think the axle is the most expensive part... if you can actually find a 78-79 Ford D60, everything else is downhill from there. I traded 4 scarpy 15x8 white-spokes for a core TH400 with a LH-drop NP241. :D
  12. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    from what i know, only the f250 Heavy Duty came with a front d60
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    here's an idea... run the Ford axles... and ditch your NP208 for a NP241 from an IFS 4x4. having the chunk on the dirvers side would be better IMO, because it would put it more inline with your line of vision, allowing you to better place it over trail obstacles.
  14. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    heh... last i checked SnowFigthers and high GVW trucks were heavy duty. :screwy:
  16. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    definetly get it.
  17. primr87
    primr87 Registered Member
    Feb 15, 2005
    20
    placerville, ca
    Im not sure about steering but i think your best bet would be crossover to make it work
  18. protechk5
    Sep 26, 2004
    2,015
    VA
    well if it was a ford d60 you would have to go out of your way not to use cross over
  19. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    With a Ford D60 you better leave the axle lowsteer crossover or seriously consider paying for Dedenbear Knuckles or the like. Ford knuckles are notoriously weak especially if you use hysteer.
    Harley
  20. u2slow
    May 9, 2001
    2,217
    BC Canada
    78-79 have push-pull steering arm on the drivers knuckle just like the Chevy. The height is different, and I think the taper is from the bottom side instead.
    If that is too tricky to deal with, you can swap on the Chevy D60 arm, or go cross over.
