Ford dual piston calipers on d60?
Discussion in 'The Garage' started by bshewmaker, Feb 5, 2004.
  1. bshewmaker
    bshewmaker Registered Member
    Sep 11, 2003
    79
    Arkansas
    Whats the deal with this? I've heard/read a little about this. Is this a direct bolt on? or total fab project? What model do these dual piston calipers come off of? Anything anybody knows will help.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Keep the Ford calipers on the Ford Dana 60. You have to find a way to use the Ford caliper bracket on the GM D60. Besides, the Ford rotor is 1/4" thinner, and succeptable to warping & cracking.
    These calipers may fit the GM D60 caliper bracket.... they're the rear caliper from a 98 3500HD w/ wrecker package:
  3. bshewmaker
    Sep 11, 2003
    79
    Arkansas
    thanks slow, I'm just getting my options together before I start to build the "Ultimate D60"
  4. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I'm in the same boat. I'm getting ready to build my D60 and only want to do it once. I'm set on the Dedenbear knuckles and probablly crossover steering. I see however, that Rockstomper also has a hybrid Ford/GM D60 brake setup ( http://www.rockstomper.com/catalog/brakes/fordgm60.htm ) that I want to look into. They say it allows for 15" rims with no grinding. Curious if anyone here has used it. I'm also thinking of upgrading to the 35 outers but I've read all the nightmares about the hub locks turning or binding.
