Ford dual piston calipers on GM D60...?
Discussion in 'The Garage' started by fortcollinsram, Sep 17, 2003.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I will most likely be replacing the brakes on the D60 I am getting. It is possible to use Ford Dual Piston calipers on a GM D60? I figure I may be able to say a little griding with the daul piston calipers as a result of thier lower profile. Do I need a Ford backing plate? Just wondering if anybody has done this and what interchange issues there may be...
    Chris
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I was thinking of doing this with my D60 way back but I ditched the idea because it requires everyhing from the knuckles out off of a Ford axle. The caliper requires the right right caliper bracket which has a 5 bolt pattern for the knuckle, so everything from the knuckle out has to be swapped (including the knuckle itself).
    Since the 35 spline conversion is a little more difficult on a Ford, plus the fact that Chevy and Dodge share common parts making used parts availability better, I decided not to do it.
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Better braking first comes in the form of a larger OD rotor because this increases your braking torque. Piston area has to get stupid large to offset a small rotor OD increase, and that opens up some bad hydraulic compromises that have to be made.
    Have a look at the now second previous body style Cummins powered Dodge (the first body the Cummins came in) 4wd front brakes. Those are some rotors !!! Aren't going to clear 15's though. 16's, yes.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Try the factory dual-piston rear calipers from a 3500HD w/wrecker prep package. I have good reason to believe they fit the Chevy D60 caliper brackets.
    The Ford rotors are only 1.25" thick. The GM rotors are 1.5" thick. Not sure if the Ford calipers can reach over them.
    They're exactly the same as the Chevy D60 brakes. /forums/images/graemlins/rolleyes.gif
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    What year(s)?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Plus....I've read and heard that the Ford D60 knuckle parts are weaker than the GM or Dodge. Too many testimonies on POR site that show the broken knuckels, due to crossover issues.
  7. u2slow
    May 9, 2001
    2,217
    BC Canada
    96-up.. this is the 3500HD with the 10-lug wheels.
  8. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Can't be exact. Might be close, but the Dodge rotors are ~1-5/16" thick, not 1.5" thick.
    My Raybestos parts book lists the GM's as having different p/n's from the Dodge's unless the Dodge has rotor casting No. 100353 on the 4500lbs front axle, then it's the same as the 77-87 non dual K30.
  9. u2slow
    May 9, 2001
    2,217
    BC Canada
    NapaOnline lists the same parts for a 93 W250 w/Cummins, and an 87 K30 SRW.
    Rotors: UBP 85843
    Pads: RBP CMX7081A (Ceramix) or RBP AE7081AM (Metallic)
    Calipers: RBP 4422070SD (left), RBP 4422071SD (right)
    I've heard about the thinner Dodge rotor before.... might have been used in the pre-Cummins era /forums/images/graemlins/thinking.gif
    EDIT: I should make sure I read your post thoroughly before I post redundant info. (Doh!) /forums/images/graemlins/blush.gif /forums/images/graemlins/wink.gif
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    I found them... along with our single-piston units for comparison:
    [​IMG] [​IMG]
  11. BXwildshot
    BXwildshot Registered Member
    Sep 17, 2001
    97
    Bronx , NY
    Did anyone ever check this out??
  12. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Yeahhhh... More info please!
  13. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    interesting....
  14. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I work at Napa and I will pull a Ford dual pistons D60 caliper and compare it to my GM D60 calipers and if they are close I may buy them and try to get them to work....
    Chris
  15. BXwildshot
    Sep 17, 2001
    97
    Bronx , NY
  16. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    True, true, but the pic on the site is a broken CHEVY knuckle!
  17. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    TTT Any more info??????????
  18. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    i have ford dual piston calipers on my gm d60 but i have ford outters aswell
  19. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Well the ford calpiers mount with those pins, not bolts. So the caliper mounting bracket would need to be changed, and the knuckle to fit the calipers. The kuckle uses a 5 lug spindle so thatll have to be changed too. I think the hubs are the same.
  20. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Approx what year application? Are these the same calipers you posted pics of?
