Ford Dual-Piston Calipers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JoeAngelicchio, Apr 20, 2001.
  1. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    Anyone running Ford Dual-Piston calipers on their Dana 60? And will a 15" with 3.5" or less backspacing work? The Super-Dutys are running 16" rims over those calipers.
    Thanks.
    <font color=green>Joe Angelicchio
    86 Jimmy 4+3, 35-&gt;39.5 tires,4spd
    </font color=green>
    [​IMG][​IMG]
  2. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Joe
    Was told by National Tire that the Eatons would fit the D60 GM with some grinding & his words (paraphrased) were "...& you can't grind enough if you have Ford Twin piston calipers...". He was referring to the 15" wheels fitting on the D60.
    Sorry [​IMG]
    Brian
    89KBlazer
  3. JoeAngelicchio
    Feb 18, 2000
    628
    Oh well had to find out. Thanks Brian.
    </font color=green>
    [​IMG][​IMG]
  4. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    If you use a Chevy rotor with the Ford 2-piston caliper,
    you'll have to remove about a 1/4", or about 1/3 of the
    material off the caliper to clear a 15" rim. At least, that
    was the case for the generation calipers I was looking
    to use. Don't even think about it if you're going to use
    the Ford rotors too. I decided that was too much material
    to remove, so I'll be running the Ford calipers and 16.5"
    rims.
    --Rob
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Interesting approach. What is the part number for those dual piston calipers from Furd?
    Are they pure bolt-in?
    Brake lines same as GM?
    Hmmmmmmmm..................got me thinking.
    Details, gents.............
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
