Ford HP44 ???s
Discussion in 'The Garage' started by beater_k20, May 15, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i've got a line on a pair of Ford HP 44s semi-locally. i'm looking into doing an SAS swap on an 88-98 K1500 frame for my 92 (which currently has a bent 2wd frame), so this axle would be perfect for that. one is complete, and the other is said to be "housing and gears". the seller also mentioned flat top knuckles on both of them, which is good for crossover. i've got a buddy with an '89 K1500 that is interested in doing the same. what parts are interchangable with a Chevy D44, or a 10 bolt that we could use to make the incomplete unit complete again?
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    From the knuckles out, stuff will interchange. And the flattops on there now?? Won't work inless you redrill them to 6 bolt pattern, Ferd is 5 bolt. I found 2 HP44s, one 1/2 ton and one 3/4, but both leaf spring and 32" pad witch. Plus a friend is giving me one. Thinking of putting it in my 97 and then trying to sell it.
  3. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    b454rat has it right. Spindles and knuckles are 5 stud. We used one under my friends dakota when he SASed it. If you don't mind keeping it mostly ford parts (aside from hubs themselves) then go for it. Sure they aren't AS interchangable as other 44s, but they will work. How much is the guy askin for them?
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    was asking like $400 for all, but said he'd make me a deal if i could pick them up soon.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    any problems i would run into bolting the complete one under a Chevy? other than it being "ford parts"?
  6. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    just the suspension. if you run a ford style coil then nothing is wrong. if you want to run leafs, you will run into a few set backs with the 1/2 ton housing. they have "C's" that the radius arms attach to. you can work around them or take them off. but if the axle is a 78-79 then good luck getting them off and still having an axle. they are cast and hollow with no axle tube going through them. look at the last few pics on this page: http://77cj.littlekeylime.com/Dana44.htm
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    its a 78/79 leaf axle, and its 3/4 ton, so i should run into no problems then?
  8. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    no, proably not.
  9. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Another added plus, the 3/4 ton have massive dual-piston calipers.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    to which point, 15" wheels will not work, correct? ah well, 17s arent that much more expensive.
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    Maybe you'll get lucky and they'll be 60's! ;)
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    no such luck, he's from a well established 4x4 site, and has been there a while. seems to know his stuff.
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    DOH. :)
