Ford injectors for LT1
Discussion in 'The Garage' started by BigJohnson, Apr 9, 2002.
  1. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    I am trying to find part numbers for a Bosch Ford fuel injector that people are swapping into LT1s for more flow. I have found a few but I am not sure which one it is. If any knows or could help me narrow down my search I would appreciate it.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Your best bet to get injectors are go with the Ford Racing injectors. They are the same injectors as the regular ford ones, but about a 1/3 of the cost. Find out who is a Ford Racing dealer in your area(most Ford dealerships are a Racing dealer as well) and tell them what size you want to run. Stock are 19 lbs, the you have 24 lb, 30 lbs, 36, and then 50 lbs. You probably are talking about going to 24 lb injector though.
    Dan
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    They're SVO injectors you're talking about I think.............guys over at www.thirdgen.org are running them in their TPI motors. One thing about them is they are 'flowed' at a lower PSI rating, hence a 22 lb/hr SVO injector will actually flow more like 24 lb/hr when used in a Chevy with 43.5 psi. Summit sells them, seems to me they cost about the same as the Accel injectors. www.summitracing.com
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Bosch and ford... same thing. I agree with the bioys that they usually are cheaper then OE GM or aftermarket delcos and work great.
