Ford Locker To Chevy?
Discussion in 'The Garage' started by bigbadchev84, Jan 14, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    I Got A Buddy That Has A Ford Dana 44 With 4:10 Gears And A Broken Axel Shaft, He Upgraded To A Dana60 But Said I Could Have The 44, It Has A Lockright Locker In It, Could I Use It In My Chevy 44 With 4:56 Gears?
  2. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    Also If It Will Work How Hard Are They To Install? Any Mods? Are They A Good Brand? Thanks
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I thought fords had the pumpkin on the other side? Or do you just want to use the locker? If so the spline count would have to be the same and I think they are the same carrier from 4:10 and up?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Can't use the entire axle, as stated, they're on the other side.
    If he broke an axleshaft, the locker may be broken.
    The carrier break is 3.92 and up.
  5. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    he broke the ujoint behind the hub, you can see it, i was wanting to pull the locker out of the ford 44 w/4:10s and stick it into my blazers 44 w/ 4:56s does anyone know if the splines are the same count? is it a direct swap?
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes they're both 30 spline, it'll be fine.
    Be sure to check and make sure the locker isn't broken from the shattered axleshaft......the shock loading is what breaks the lockers, not actual parts shattering it.
