Ford relay setup
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, May 14, 2001.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    How can I put a ford relay on my truck? I know how to hook up all the wires to the relay, but when I run a wire down to the starter, what do I hook it up to? Do I hook it up to the lowermost post?
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I put the remote starter solenoid on my truck also - I assume that is what you mean? I will check my truck tonight and see where the power wire is hooked up to...I can't remember right now. I got the kit from MAD Enterprises up in Northern Cal - Mark Hamilton is his name, really quality guy.
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I am not sure I follow your ?
    But you need to engage the little gear( 5-10 theet) to the big ring gear(over 100 theet),this means
    you need to apply 12volts to engage the gears. If you only apply 12 volts to the lower post only the
    motor shaft will turn. Hope this helps ya
  4. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    from the relay you would have too run like a 2 gauge wire too the big post on the starter.Then from the big post run like a 8 gauge wire too the s marked tab just a short jumper.The other small wire that hooks too your starter that powers the truck will have too be run up too the relay now.Hope this is what you where asking.I'm going too do the same setup on mine.
  5. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    Bingo! thanks for the info, that is what I was looking for.
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Just a suggestion, but the Ford relays aren't all that great[​IMG]. I have replaced 3 in the last 2 years[​IMG]. Go with a constant duty solenoid from an RV dealer.
    Where are you in AZ[​IMG], and what are you running. You might want to fill out your profile. HTH
    <A target="_blank" HREF=http://fwp4x4.coloradok5.com>http://fwp4x4.coloradok5.com</A>
  7. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    You'll want to hook up the cable (preferable a 0 or 1 gage) to the large terminal on the battery. You'll also have to make a jumper to the solenoid input on the starter so it will get power at the same time as the starter motor, otherwise the bendix won't kick out and engage the flexplate/flywheel.
  8. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    Forgot too mention that you'll have too run the old soliniod wire too the relay.We have about 8 ford diesel trucks that we drive alot and start and stop about 30 times daily and have never had one go out yet.Maybe the diesel ones are heavyer duty.Our were just lucky.
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have to agree with FWP about the "ford" relays. I did this to my race car and still kept burning out the relay's. I, in desperation one day, took the relay from my meyers plow to use. That one lasted till I sold the car. 4 years. look the same, but are different inside.
    your right. I don't understand the jeep thing!
  10. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    I have a '77 with a 400ci in it. I just asked, because the top post (with the + cable from the batt.) is broke off, and I have a few ford relays lying around that my dad bought but never used. I also liked being able to tell what was wrong (if the thing wouldn't start), the starter, or relay, on my old ford. It is a lot easier to test if the relay is up on the fire wall and seperate from the starter.
    Grind it 'till you find it
