Ford Superduty front driveshafts (1350 CV)
Discussion in 'The Garage' started by ryan22re, Jul 20, 2006.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Anybody running one in their k5 or have one under their towrig and want to tell me how long it is, and what tranny/tcase you are running? Brand new one at the stealership runs about from 250-300 depending on auto or stick drw or srw...I just don't know the differences in the fords to know what I should be looking for. I'm sure that they can be had cheaper somewhere else...junkyard, ebay, etc. I guess I would want the longest one possible cause I figure that it would need to be cut shorter anyway, but I dunno...
    Thanks in advance.
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i bought that same shaft off ebay from that guy. came within a couple days. its a quality shaft. i dont have it measured but it looked to be bout 7" longer than the stock k5 (700r4/208) shaft i have now i plan to run that in the rear once i do the sye on the 241 i just bought.
  4. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    I picked up two at the junk for my blazer for $300. The 03 and newer f-250 front driveshafts.
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Whats the difference between the 03 and newer over the 99-02 super duty's?
  6. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Unless I am mistaken, 02 and down are 1330 cv's. Flex the same as 1350, just not quite as strong.
    Jimbo
  7. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    I'll have to measure the one on my 2000 Super Duty.
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im pretty sure they are all 1350's
  9. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    What kind of slip does it have (length), and have you found a 32spl flange to make it work?
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    there isnt much slip, maybe 5-6" total but it should be fine for a rear shaft, dont know if it would work with a flexy front
  11. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    I dont have any lenght numbers right handy but the Ford 1350 shafts will need to be shortened for use in a GM front.
    I have gotten a couple of the new ebay Ford 1350 shafts and they are well worth the money and the seller is good to deal with.They are not made by Spicer but all the joints are 1350s and they have a 2" pilot.
    You should be able to get a couple of degrees better angle out of them with alittle grinding on the H part of the CV without taking it apart where as the Spicer ones are restricted internally.
    Again I dont have any #s handy and its been a couple months since I was messing around with them on the bench but could probably dig out my angle finder and camera again!
