Ford Superduty Shock Towers installed *pic*
Discussion in 'The Garage' started by MTMike, Jul 1, 2005.
  1. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Very easy to install. 1 hole lined up w/ the factory shock mount hole, the other 2 I drilled out to 7/16". I mounted them in such a way to allow the maximum possible suspension compression on the up stroke, and nothing more. The rest is all droop :D
    I removed the inner fender well for ease of install. They won't fit w/ factory fenders, but what I did was cut a notch into them for the shock towers to fit, and then reinstalled them.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Nice work.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Looks nice, now we need some action pics! :D
    Off topic, but what size hole did you drill when you moved your front spring shackle mount?
    :xmas:
  4. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    nice, what year superduty did they come off of?
  5. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Less than 2 weeks for action pics :D
    IIRC it was 7/16"
    I think '99-'05. Got them new from the f*rd stealership.
  6. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    just for kicks, what did they cost ya?
  7. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    And once you do this can you use matching shocks front and rear?
  8. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    They were $27 & change each from the F*rd dealership
    Yes, I have the same make/model shocks front & rear. The rear could use a couple inches more up travel, but not bad enough for me to worry about it now.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Looks almost exactly like mine. I notice you also moved the shackle mount up. Good choices...
