ford tower for long travel ?
Discussion in 'The Garage' started by bscappell, Oct 12, 2004.
  1. bscappell
    bscappell Registered Member
    Oct 4, 2004
    10
    washington
    hey guys,
    i am getting ready to do a 6inch lift on my truck and was wanting to do the long travel shock trick with the ford mounts. my ? is how do you calculate the spot to mount the tower at? and you just use the stock mount for the lower one correct?> i have dual shocks so which one do i use? or is it the same lower mount for both, i forget? probably go with the 14" travel Bilstein 5150 or pro comp adjustable monotube reservoirs the front, not sure about the rear, any ideas for more art. in the rear?
    thanks a lot for the help,
    Brandt
    /forums/images/graemlins/usaflag.gif
    email if you want bscappell@aol.com
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Click here - F250 Shock towers
    I just did this on my suburban, finally. I'm using the same shocks as Steve. Yes you can use the lower stock mount. I used the two holes on the frame from the stock upper mount and added a third hole. I also enlarged the holes to 1/2 inch. I mounted mine about dead center of the shocks overall travel. Once I had that, I used the shock to figure out were to mount the tower.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Here is another option.
