Ford Towers Installation question ****UPDATE NEW QUESTION*****
Discussion in 'The Garage' started by TxK5Blazer, May 24, 2004.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I am installing my ford towers this weekend and wanted to know the best way to get the rivits out of the old shock mounts to remove them? Jason
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: Ford Towers Installation question
    personally, hand grinder, grind them down till the head is gone and you can see the circle that defines them, then use a punch and hammer and beat them out.
  3. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    that is exactly what I was thinking....Jason
    anybody got any other ideas that might be a little better?
  4. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Yep what he said /forums/images/graemlins/waytogo.gif I just done this last weekend.
    I ground the head off, used a metal chizel to pop the hanger off then smacked the rivit out with a punch instead of trying to punch it though two layers, but yeah thats it.
    Tryed the torch on my other frame and it welded the rivet in. What a pain /forums/images/graemlins/doah.gif
    The easiest way I figured on setting the height of the shock tower was to bolt the shock to the tower, figured out half stroke and wired it to the point. Then once the frame hanger is off, you can trim the wheel well if needed and mount the lower point of the shock to the axle. Then I used a couple of welding magnets to hold the tower in place, in a straight line, while I crawled under and marked the holes on the back side. Then I transfered the holes to the other tower by drilling it, then setting them back to back.
    Dont forget about your fuel lines and you'll probley have to drill out the tower hole for the shock to 7/16" and the frame holes to 1/2" /forums/images/graemlins/waytogo.gif
    good luck, post pics
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I used my air chisel/hammer. I had both of the stock mounts off in about 30 seconds.
    Don't just go bolting up your towers at, "half stroke" of your shocks. You need to actually measure so that when you're at full stuff, your shock will not bottom out. Then allow as much as possible for the shock to have for droop to allow for maximum travel. I'm not exactly sure where my shock sits at ride height in reference to its capability, but I know I can go all the way into the bumpstop and then some without bottoming and the rest is set up for max droop.
  6. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    hey tim, what's the travel on the gagriels #g63438???
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    12.53"
  8. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks's
    another question what shocks do you use with your ford towers???
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have G63438 at all four corners right now.
    If I ever change I'm going to buy bilstein 5150s with 14" of travel....but I'm liking the gabs right now and they were super cheap.
    If you know me all that well I'm willing to spend money where I feel it is due, but I'm typically a cheapass.
  10. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    how do I go about figuring this I am kinda stumped right now with buying a new house I have a lot on my mind and can't think how to figure this.....Jason
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Easiest and most accurate way is to take the shocks off and find something to "ramp" on. Best option is some place to get fully crossed up, almost balancing on opposite corners with the drooped tires barely (or not) touching. Then mount the shock so that it is almost closed on the compressed side. This gives you max use of your shock. However, it should be obvious that you need to do any bump stop changes before setting the shocks...
  12. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    Thanks I will do some measuring on this and try this idea if I can find a place to ramp on not much around here near my house but I will try...Jason
