Fouling Plugs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Nov 10, 2000.
    My beast keeps fouling sparkplugs every two months or so, what could be causing this?
    '84 K5
    Chevy in my blood.
  1. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    Gas or oil causing them to foul? My last motor burned oil sooo bad, that a drive to my favorite camping spot would foul them. And that's only a four hour drive! If it's oil, your rings are most likely done, and you will most likely need a rebuild, or new motor. If it's gas, make sure your choke is working properly(if it sticks you could get a running rich effect) and make sure the carb is adjusted properly. Change you air cleaner to make sure your getting sufficient air flow. And make sure you have the right plugs for your application. Good luck, and I hope this helps!
  2. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    If it is oil fouling, check the valve guides first. The fix isn't too difficult and you may get another 50,000 miles out of it.
  3. Sorry I'm a novice...Valve Guides?
    '84 K5
    Chevy in my blood.
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    The valve stems have little seals (rubber), and a bushing that can leak oil into the cylinder from the heads, that could foul up the plugs(that's the best way I can describe it). Are all the plugs getting fouled at once? Usually if it's the heads or rings causing problems, they don't all screw up at once. If it's all of them, look for a rich condition from the carb. Those Haynes/Chiltons manuals have color pictures that help troubleshoot these kind of plug problems.
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    If you get the ol' "Puff O' Blue" when you first start your truck, chances are your valve seals(guides) are shot....
  6. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Hey guys,
    I've got 180,000 on my original motor ... just started to puff at start up. I know I'm eventually looking at replacing the motor, but it runs so strong, I'm tempted to replace the oil seals.
    Do you think I'm wasting my time?
  7. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I have a '74 that uses oil badly. It was fouling plugs in a bout 60 miles. I added and HEI ignition that has an MSD circuit board inside (from a swap meet) and Bosch platinum plugs. It doesn't foul at all now. I was truly amazed. I'm sure my seals and rings are pretty shot, but like backlash says it still runs really well. I've got about 150,000 miles on it.
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  8. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    mine does that except every couple of weeks, I just change
    them...probaly not the smarest thing to do,
    ..........and one time at band camp.........
  9. Daveytree
    Daveytree Registered Member
    Nov 11, 2000
    57
    Kingman Arizona, U.S.A.
    One quick temporary fix will cost about 6.00. They are called Spark Plug Defoulers. Napa auto parts has them. What it is is basically a spacer and a cover that threads into your spark plug hole in the block, and then the spark plug threads into that. It is inexpensive, and alot easier than changing out plugs all the time.
