Found a D60!!! with 14bff
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txfireman110, Jan 9, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Found a K30! Has a D60, but not sure about the rear? 14bff or 14bSf??
    Looked at the truck 1/11/03.........
    This truck has the D60!, 14bff!, and to make it better, it comes with a 454/TH400/NP205 which all seem to be in great condition!! /forums/images/graemlins/thumb.gif
    Worth $2,000?? /forums/images/graemlins/thinking.gif /forums/images/graemlins/grin.gif
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Re: Found a D60!!! what\'s in the back?
    should be a full floater,Look at the hub by the lug nuts.there should be a plate with a circle of bolts. If so this is a Full floater
  3. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    That's what I was thinking, but I haven't actually seen it yet. Going to check it out on Sunday!
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    unless its been changed out its a 14 full floater
    Later
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well when you go look, see if it has FF hubs or SF hubs,
    being a 30 it will be an FF
    good luck
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Later
    yup, what he said.
    and as for the front, 85 is a good year. unless they have been changed you should have the better stock inner shafts on the 60. they shouldn neck down. mine is out of an 85 as well.
    wish i had grabbed the gov lock out of it as well.
    Grant
  7. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    dunno what year rig my d60 came out of.... but the year stamped in the housing is '85... guess I lucked into the non-necked down shafts too. Had no idea when I went shopping for it last year that there were good/bad years for da 60. lol!
    j
  8. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    is 85 + the only yrs they had the "good" 60s?
  9. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    2000$ and it comes with a 454 does it run? If you dont want it il take it.
  10. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    it does run. there is a tapping sound in the engine though, i'm not sure, but I think /forums/images/graemlins/thinking.gif it is just the rocker arms need adjusted.
  11. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    If this truck is a SRW K30 it will have a NP208 t-case and a 14FF. If its a DRW it will have a D70 and NP205 t-case.
  12. one ton burb
    one ton burb 1/2 ton status
    Nov 15, 2003
    119
    Ontario, Canada
    [/ QUOTE ]only cucv military one tons were like that all normal one tons should have the np205 unless it was changed
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'll 2nd that. My K30 had a 400/205 and it is an '86.
