Found a fixed yoke 208 pass drop........turns out it's a NP241
Discussion in 'The Garage' started by stallion85, Nov 19, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    My bud is about to scrap an 89 1/2 ton Dodge that has a fixed yoke 208. Can someone refresh my memory why it will not work as a replacement for my 208?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    It will if you make the bolt patter fit. Its rotated like 180* or something like that.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    bolt pattern for the adapter is 90* off counter clockwise.
    you can get a custom clocking ring from diy4x and clock it down and swap the correct input into it and run it in your truck.
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Cool thanks!
  5. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    or bolt it up and its clocked completly flat, clockign rings suck in my opinion, they leak like no tomorrow
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the dodge 208 i have, if you were to just bolt it up, the front output would be above the floor. you need to clock it down.
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    turns out it's a NP241. Can I still use it? Also the input shaft is not 32 spline, I wonder if I could swap the one from my NP208 over to it.......
  8. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    You sure its a 241?? Ive never heard of a fixed yoke 241 that was stock.
  9. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    It says 241 on the stamp :)
  10. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Still looks as though I have to find a 32 spline input shaft as the 208 one will not work.
  11. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    dodge did make fixed yoke 241's i believe. you need to swap 32spline input into it to make it work, and some kind of clocking ring i believe.
