Found broken wire, anyone know what it goes to?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4blazer, Mar 11, 2002.
  1. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    There is some sort of switch on my gas pedal that the upper end of my pedal arm contacts at almost full throttle. It has 2 wires connected to it. The forward wire has been broken off from where ever it goes. Does anyone have a clue where it connects?
  2. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Probably a kickdown switch. One to ignition hot power, one to the tranny.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Is your tranny a TH400? If so its the switch for passing gear. TH400 use a switch on the accelerator and a solinoid in the trans to kick it down into passing gear. Instead of a cable hooked to the carb linkage like a th350.
    As said in above post one side of the switch is hot from the ign. The other side goes down to the trans. You should find the wire going into the trans body just above the pan. On the drivers side I think. Its been a while since I'v worked on a 400 and my memory aint as good as it used to be/forums/images/icons/crazy.gif
  4. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    it sound like a turbo 400 tranny to me also
  5. 4x4blazer
    Jun 14, 2000
    278
    Louisiana
    Yes, it is a turbo 400 tranny. But it is not original, I swapped it in to take the place of a 700r4 a while back. So is it still the same deal?
  6. Skigirl
    Apr 2, 2001
    2,563
    Yes, same deal.
