Found deal on Orbital Batteries.
Discussion in 'The Garage' started by Moose, Jul 13, 2004.
  1. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Hey Sunvalley Battery 623-582-6547 has a bunch of Blem Red Top Orbital batteries selling for $50.00. These are the gel filled and have the post so you can add you acc. too. Give them a call ask for Sean or Don. There in Phx, Az /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    not a bad price but isnt the yellow top better? i am getting a blue top that is made by another company. When I get it on Saturday I will post its specs.. has a better warranty than OPTIMA and is only $135
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Are they marked any differently then standard red tops? I already have a redtop with a warranty threw Azone. I want to run some Dual bats but I would like a bat under warranty.
    Harley
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    Harley
    from what I saw the CCA sucked.. like 700cold crankin amps.. the bluetop im lookin at is like 950 /forums/images/graemlins/woot.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You don't need 900 amps of current to start your truck anyway. "CCA" is all marketing hype.
  6. Xtreme Off-Road
    Xtreme Off-Road Registered Member
    Apr 27, 2003
    48
    Ontario, Canada
    I dont think so. Winters up here in canada will go down to -40, and that is when the "cold" cranking amps really count.
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Summers down here will melt the posts off of a battery. So it is more of CCA are more of chilly cranking amps not cold.
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I use to run two 1050 cold cranking amp batteries together. Coldest days of the winter and mine would crank right over but my neighbors brand new fuel injected truck wouldn't start.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Here it gets plenty cold in winter. I've always had good batteries but I've had customers with some pretty crappy batteries and they seem to start the vehicles just fine.
    Keep in mind that the plates in the battery must be thinner to provide more current from a battery with the same phsycial size case.
    Most of us here are using a group size 78 battery and the difference between the durability of an 875 CCA group 78 and a 1000 CCA model is pretty significant.
    Comparing two batteries of the same physcial size, theoretically the one with lower CCA's is more durable and should last longer.
    The warranty will probably be better on the latter though.
  10. Moose
    1,062
    Glendale, Arizona
    Hossbaby, I think they are missing the sticker or something. Give them a call talk to Sean today. As for CCA i donn't know what they would be but I have always used the redtops in daily drivers and in the race truck. I know that they sell a lot of them at the regular price. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif
