found out my redline kinda, and why are by burn outs pegleg? *video*
Discussion in 'The Garage' started by BranndonC, Dec 10, 2005.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
  2. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    What kinda locker do you have?
    Rene
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    powertrax no slip, same design as a detriot, almost identical from what i can see
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    One immediate difference I see between the powertrax and detroit is on the powertrax the springs are between the "coupler" and "driver" as they are called in the diagram you posted. This helps the two parts seperate (read. open diff). Detroits have springs on the outside (pressing between the carrier and the backside of the coupler). I am not saying which performs better but from a design standpoint the powertrax would seem to want to stay unlocked much more than a detroit to me.
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    my brother said someone he knew with a powertrax is now a peg leg because of a shim or something, probably didnt set it up right
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
  7. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i agree with this one.
  8. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
  9. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i'll go straight for a while before i try it today :)
  10. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Dude branndon that thnig is freaking sweet. Now you make me want to put a big block in my blazer. I keep telling myself I dont need that right now but it does look convincing. What did you do to that caddy motor?
  11. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    check out my website www.branndoncoelho.com under the jimmy then pictures, then the last picture is the specs of the engine and truck
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Regarding the "pegleg" issue, it's quite obvious that you either do not have the Powertrax installed correctly or something else isn't correct. It should quickly and easily lock whenever torque is applied through the driveshaft and only unlock when coasting.
    You did reinstall those little shim type things that fit between the stock side gears and carrier, didn't you?
  13. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yes, the large thin washer looking things?
  14. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    hijack
  15. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
  16. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    I believe the installation manual has a whole list of tests and measurements you can take to make sure everything is working correctly.
  17. chevy500
    chevy500 Newbie
    Oct 21, 2005
    new mexico
    It should work when you hammer the gas. I have a detroit in the rear and when i spin the tires they are locked and carry it sideways going down the road. I have not dealt with the power trax before but it doesn't seem right that it doesn't hold together. With the torque your motor puts out you should be able to spin the tires really easy. If you have the funds for it i recommend you getting the pro-street iron heads from cad company. I put them on mine and you can really tell the difference in the performance.
