Found something, dunno what it is!!
Discussion in 'The Garage' started by jimmyjack, Mar 30, 2002.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    The other day I was playing around under the blazer and found a sender between the #5 and 7 spark plugs with a green wire hooked to it. I was thinking its the water temp sender. Any other ideers?
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Oil pressure maybe but mine is on the right side between 6&8
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Nope, not oil pressure. Those are both on the driver side and I've replaced them both. I thought the water temp sender was on the manifold or the radiator. Dont think I have any other sensors. I dont have a computer either.
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    If you mean the sender on the passenger side right above the oilpan, thats the knock sensor, it retards the timing if it "hears" knocking in the engine, If you hold a timing light on the marks and tap the exhaust manifold with a hammer the timing should jump back.
  5. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    water temp
  6. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    i believe that is water temp, disconnect and see what your gauge does or pull it out and see if water runs out, should go into a water passage in the head
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    I believe it's water temp, too. I have seen several weird places for these fittings on the GM motors. /forums/images/icons/tongue.gif
  8. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    I messed up and forgot I was laying looking up at the engine so its the 6@ 8 plugs and it IS the water temp sender. I was having a dyslexic moment.
  9. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    My water temp is between 5 & 7. You do know that 6 & 8 is on the passenger side? I never seen a water temp for a 350 on that side. Our wiring harnesses are set up for drivers side water temp.
  10. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    hmmmm...is that kinda like the dream i had once where i thought if i could put a new fuel pump on my wife it would straighten her out, didn't work, we got divorced anyway
  11. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Yeh, Like I said I had a "moment" there. This engine and its components are all backwards.
