Found something Intresting on my Dana 60 Hubs, Anyone else?
Discussion in 'The Garage' started by Mudbug1979, Oct 20, 2006.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    While trying to get the K ready for the East coast Thump at Uwharrie. I was trying to put in some locking hubs on my D60 Srw front axle and there aren't any grooves cut into the hub for the large locking ring to hold the body of the hub in. The only place for a snap ring is on the end of the axle shaft and that's not going to hold any amount of torque in. Anyone else come across a set of these. Thanks, Jeremy.
  2. Mudbug1979
    Aug 4, 2002
    439
    Anyone else seen this?
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I have never seen that. looks like you are going to be running slugs.
  5. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    What did it have when you took it apart?
  6. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    Sounds like new hubs....
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yep, I have seen it. Matt (az-k5) and his dad built a custom dualcab shortbed Chevy 1 ton. The D60 he had in the front of that was the same way. He had to take the hubs in and have that groove machined in so the locking hubs would install correctly.
    I can't remember offhand why we decided it didn't have that groove but I am sure he remembers.
    Harley
  8. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    what would you use to hold them in??
  9. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    my slugs are held in by a snap ring on the axle shaft. I have a dust cap that is just pressed into the hub.
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    That truck was a converted dually before we got it. That was the only conclusion we came to.
  11. Mudbug1979
    Aug 4, 2002
    439
    I took those bad boys off, put them in a lathe and cut a groove in it. Works like a champ now. Maybe we might actually get to wheel this year...
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    My D60 is like that also. It came from a '77 K30 with factory drive flanges. The flanges or hubs are held in by the snapring on the stub shaft.......but if you break a stub it can spit out the flange/hub.
  13. 78Buford
    78Buford 1/2 ton status
    Apr 1, 2005
    264
    Ohio
    Yep, been there, done that. I found the flange, but there is a reason that I am running the bottom of a Powerade container with sealant around it on my driver side hub....I didn't find my cap. :D
